Available functionality depends on the system you are using. See the Product comparison chart for more information.
To control when your system archives and how the system should respond in the event of failure, set the following settings. Your system automatically archives recordings if a camera's database becomes full.
Archiving Times |
Specify when you want your system to automatically move recordings to your archiving path(s). You can specify up to 24 archiving times per day, with minimum one hour between each one. Select the hour, minute and second values and click the up and down buttons to increase or decrease values, or simply overwrite the selected value, and then click Add. The more you expect to record, the more often you should archive. |
Send email on archiving failure |
Your system automatically sends an email to selected recipients if archiving fails if you enable this. You must also enable the email notification feature. Recipients are defined as part of the email notification properties. |
Send SMS on archiving failure |
Select if the system should automatically send an SMS if archiving fails. You define the recipients of the SMS notifications as part of the SMS notification configuration. The setting is only available if you have enabled SMS notifications. |
Archive on event |
If selected, your system starts archiving when a certain event occurs. Select the event from the list. |
© 2019 Milestone Systems A/S
