You can set the following properties for master servers and slave servers:
Master server properties
Enable as master server |
Select to enable as master server. |
Timeout |
Set timeout of slave update. See Update Status on Slaves further below. |
Add |
Lets you add slave servers. Select Master Server in the list and click the Add button. |
When you select Master Server, the Delete button is disabled and the Add button is enabled (provided you have selected Enabled as master server). This allows you to add slave servers to the master server, but prevents you from deleting the master server.
Slave server properties
Address |
IP address of the slave server. |
Port |
Port number of the slave server. |
Delete |
Remove a slave server from the list of slave servers. Select the slave server in the list and click the Delete button. |
If you want a slave server to become a master server, clear Enable as master server on the original master server and click OK. In the navigation pane, right-click the slave server which you want to become master server and select Properties. Then select Enable as master server. Next click Add to add slave servers to the new master server.
Update status on slaves
In the Master Settings Summary and Slave Settings Summary table area, you can verify/update added slaves by clicking Update Status. A status dialog runs and afterwards informs you of the status of your slave server(s).
© 2019 Milestone Systems A/S
