Once you have added hardware output, such as lights, sirens, door openers and more, you can associate the hardware output with events. This way, particular hardware output can be activated automatically when events occur. Example: When a door is opened (hardware input event), lights are switched on (hardware output).
When making the associations, you can select between all output and events defined on your surveillance system server. You are not limited to selecting output or events defined on particular hardware devices.
You can use a single event for activating more than one output. You cannot delete associations, but you can change your selections or select None in both columns as required.
Note: If you have not yet defined any suitable event or output, you can quickly do it: Use the Configure events list and/or Configure Output... button, located below the list of associations.
© 2019 Milestone Systems A/S
