You can specify IP address ranges which your system should recognize as coming from a local network. This can be relevant if different subnets are used across your local network.
If you click the Add button, you can set:
Start Address |
Specify the first IP address in the range. |
End Address |
Specify the last IP address in the range. |
Repeat the process if you want to add other local IP address ranges.
© 2019 Milestone Systems A/S
