Configure server access
- Expand Advanced Configuration, right-click Server Access and select Properties.
- Specify required properties for Server Access, Local IP Ranges, and Language Support and XML Encoding. Your system comes with two simple schedule profiles, Always on and Always off, which you cannot edit or delete. If these do not meet your needs, you can create any number of customized schedule profiles for each camera. You can reuse a customized schedule profile for more than one purpose if you want to.
- Save your configuration changes by clicking Save in the yellow notification bar in the upper-right corner of the Management Application.
When you use this option, you configure client users separately from clients' access. See Add individual users, Add user groups, and Configure user and group rights.
© 2019 Milestone Systems A/S
