About server access
You can configure clients' access to your system's server in two ways:
- Wizard-driven: Specify how clients access the server and which users can use clients through guided configuration. When you use the wizard, all users that you add have access to all cameras, including new cameras added at a later stage. If this is not what you want, specify access settings, users and user rights separately.
- Through advanced configuration: This was known as Image Server administration in previous versions.
© 2019 Milestone Systems A/S
