Specify the following properties for Central:
Enable Milestone XProtect Central connections |
Enables the use of Central connections, allowing you to specify further properties. |
Login Name |
Type the name used for the connection between your system and Central servers or the MIP. The name must match the name specified on the Central server or in the MIP. |
Password |
Type the password used for the connection between system and Central servers or the MIP. The password must match the password specified on the Central server or in the MIP. |
Port |
Type the port number to which the XProtect Central server or the MIP should connect when accessing the surveillance system server. The port number must match the port number specified on the XProtect Central server or in the MIP. The default port is 1237. |
© 2019 Milestone Systems A/S
