Enable XProtect Central
- Expand Advanced Configuration, right-click Central and then select Properties.
- Enable the use of Central connections by selecting the Enable Milestone XProtect Central check box.
- Specify required properties.
- Save your configuration changes by clicking Save in the yellow notification bar in the upper-right corner of the Management Application.
© 2019 Milestone Systems A/S
