Fisheye lens technology allows you to view panoramic video through an advanced fisheye lens.
To use fisheye lens technology, you must enable the technology and, in some cases, enter a special license key. If you are unsure if you need a special fisheye license key, contact your system vendor for further information.
Enable fisheye lens support |
Select the check box to enable use of the fisheye lens technology and to be able to specify further properties. |
Immervision Enables® panomorph RPL number |
When you enable the panomorph support functionality, you must also select a Registered Panomorph Lens (RPL) number from the ImmerVision Enables® panomorph RPL number list to ensure that the lens is correctly identified and configured with the lens used with the camera. You can usually find the RPL number on the lens itself or on the box it came in.
For details of ImmerVision, panomorph lenses, and RPLs, see the ImmerVision Enables website. |
Camera position/orientation |
Choose whether the camera is mounted in the ceiling, on a wall or on ground level. |
© 2019 Milestone Systems A/S
