Set the following properties for privacy masking:
Enable |
Enable the Privacy Masking feature. |
Show grid |
Turn the grid on or off. Turning the grid off may provide a less obscured view of the preview image. Select areas to exclude the same way as you would when the grid is visible. When on, the preview image is divided into small sections by a grid. To define areas which should be excluded from privacy masking, drag the mouse over the areas in the preview image while pressing the mouse button down. The left mouse button selects a grid section and the right mouse button clears a grid section. Selected areas are highlighted in red. |
Show privacy mask |
Turn the red area indicating privacy masking on or off. Turning off the red area may provide a less obscured view of the preview image. |
Clear |
Clear the privacy masking. |
© 2019 Milestone Systems A/S
