Output (properties)
When you configure video and recording for specific cameras, you can also associate a camera with particular hardware output, for example the sounding of a siren or the switching on of lights.
Associated output can then be activated automatically when motion is detected in video from the camera, or manually when XProtect Smart Client users with the necessary rights view live video from the camera.
- In the Available output list, select the required output. It is only possible to select one output at a time. If you have not yet defined any suitable output, you can quickly do it: Use the Configure Output button, located below the other fields.
- Click the >> button to copy the selected output to the:
- On manual activation list, in which case the output is available for manual activation in XProtect Smart Client.
and/or
- On motion detected list, in which case the output is activated when motion is detected in video from the camera. If relevant, the same output can appear on both lists.
- Repeat for each required output.
If you later want to remove an output from the one of the lists, select the output in question, and click the << button.
© 2019 Milestone Systems A/S
