To change any of the default file paths:
If you change the default recording or archiving paths and there are existing recordings at the old locations, you must select whether you want to move the recordings to the new locations, leave them at the old locations, or delete them. Milestone recommends that you choose to move the recordings to a new location.
© 2019 Milestone Systems A/S
