The help is a built-in set of HTML files that opens in your default Internet browser. As the help opens outside of the system, this allows you to switch between the help and the system itself. The help system is context-sensitive. This means that when you access the help while you work in a particular window or setting, help that matches that window/setting opens.
Use the help system
Use the help tabs Contents, Index, Search or use the links inside the help topics.
Print help topics
If you need to print a topic, use your Internet browser's printing function.
© 2019 Milestone Systems A/S
