Import changes to configuration
- From the menu bar, select File > Import Changes to Configuration...
- Select Online verification if the new hardware devices and cameras listed in your CSV file are connected to the server and you want to verify that you can reach them.
- Point to the CSV file, and click the Import Configuration from File button.
See also About importing changes to configuration.
© 2019 Milestone Systems A/S
