Uninstall XProtect LPR
If you want to remove XProtect LPR from your system, uninstall the two components separately using the regular Windows removal procedure:
- On the computers where the XProtect LPR plug-in is installed, uninstall Milestone XProtect LPR [version] Plug-in.
- On the computers where the XProtect LPR server is installed, uninstall Milestone XProtect LPR [version] Server.
© 2019 Milestone Systems A/S
