This tab provides information about the selected camera:
Name |
Description |
Enable |
LPR cameras are by default enabled after the initial configuration. Disable any camera that is not used in connection with LPR. Disabling an LPR camera does not stop it from performing normal recording in the surveillance system. |
Camera |
Shows the name of the selected camera as it appears in the Management Application and the clients. |
Description |
Use this field to enter a description (optional). |
Change Server |
Click to change LPR server. Changing the LPR server can be a good idea if you need to load balance. For example, if the CPU load is too high on an LPR server, Milestone recommends that you move one or more LPR cameras to another LPR server. |
© 2019 Milestone Systems A/S
