If you use one of the XProtect Professional VMS products, for example XProtect Express, and decide that you want to use the additional features and functionality found in a different XProtect VMS product, for example, XProtect Professional, you can upgrade your system.
First, you must place a trade-in order for your current XProtect Professional VMS product and purchase a base license for a more advanced XProtect VMS product. When you do this, you receive a new software license file. The software license file defines which XProtect Professional VMS product you can use. Therefore, you do not need to install anything, only import your new software license file.
Your settings from the previous product are the same in the new product. You must redefine some of the old settings and define the settings to the new functionality included in your more advanced and feature-rich XProtect product to make use of the expanded functionality.
Example: If you upgrade from XProtect Express to XProtect Professional, you should, among other things, be aware of:
For more information about the various differences between products, check the Milestone website.
If you have installed a trial version of any XProtect Professional VMS product, you can also upgrade to a licensed version of the XProtect Professional VMS product. To do this, you purchase a base license as well as the needed hardware device licenses and import the software license file. Keep in mind that the retention time for a trial installation is maximum five days. As a result, you never have more than five days of recordings once you have imported the software license file. Remember to manually change the retention time in the Management Application for your product.
© 2019 Milestone Systems A/S
