Drag camera from map to Smart Wall
If your view contains both a map with cameras and a Smart Wall, you can drag cameras from the map to the Smart Wall view item. For example, this is a good way to quickly share video when an alarm triggers.
Tip: You can also drag cameras from maps in other displays, such as floating windows or secondary displays.
Smart Wall1 Smart Wall2
© 2018 Milestone Systems A/S
