If you are using XProtect Smart Wall, you can display a camera navigator.
Requirements: You have added a camera navigator to your Smart Wall as described in Add camera navigator to view or Smart Wall.
Steps:
and select a display option, for example Primary Display. For more information, see View live or recorded content in XProtect Smart Wall.When you send a camera navigator to a Smart Wall, the navigator uses only the original settings. That is, if you select a different camera in the view, the Smart Wall does not display the change.
© 2018 Milestone Systems A/S
