Work with views in the XProtect Smart Client – Player
You create and manage views by clicking Setup on the XProtect Smart Client – Player toolbar.
The Project pane
A project in XProtect Smart Client – Player is a collection of files that are created when video is exported in database format from XProtect Smart Client.
Your user settings, including information about your views, are stored as part of a project.
Passwords
You can assign passwords to a project, for example, so only people with permission can view a video. You can also assign passwords to devices when you export them. To avoid having to keep track of several database passwords, you can assign a single password to the overall project. If you do not assign an overall password and you have databases with passwords added to your project, you will be asked to enter a password for each database when you open the project. If you assign a password to a project, you cannot delete it. However, you can change the password or create a new identical project in the Project pane:
The Views pane
In the Views pane you can add, create, edit, or delete views. For more information on what you can do with views, see Views.
The Overview pane
The Overview pane displays the cameras, microphones, speakers, HTML, images, and plug-ins assigned to the project.
When you delete a device, this does not delete the actual database files associated with the device, it just removes them from the project.
Link Audio
You can link audio to a device:
© 2018 Milestone Systems A/S
