Tip: Use the color picker tool to use an existing color from the map.
Adjusting Gradient
Use the Gradient slider to adjust how the element color fades from left to right.
Dragging the slider to the far right will make the element color fade instantly. Dragging the slider to the far left will make the element color almost not fade at all.
Drag the Gradient slider to the required level, then click the map element to apply color and gradient.
Adjusting Opacity
Use the Opacity slider to adjust the transparency of the color fill.
Dragging the Opacity slider to the far right will make the color completely transparent, while dragging the Opacity slider to the far left makes the color completely solid.
Drag the Opacity slider to the required level, then click the map element to apply color and opacity.
Advanced Color Change
You can fill map elements with any color you like. Click the Color Selection window's Advanced button to access the advanced color selection options.
Use the color slider to select the main color shade, then drag the color circle to select the required tone.
- or -
Type the hexadecimal color code in the Hexadecimal notation field.
© 2018 Milestone Systems A/S
