After creating a building and adding levels, you can add the cameras. If a default level has been specified, the cameras are associated with it. Otherwise, the cameras are associated with the first level. You can change this and associate the cameras with any of the levels in the building.
Requirements:
Smart map editing has been enabled on your Smart Client profile in Management Client.
Steps:
Add a camera. If no levels are selected, the camera is visible on all levels.
© 2018 Milestone Systems A/S
