Instead of using images or shapefiles to illustrate buildings, you can add an outline of a building. Afterwards, you can change the dimensions, angles, and size to match the shape and position of the actual building.
Requirements:
Smart map editing has been enabled on your Smart Client profile in Management Client.
Steps:
and place the cursor in the relevant position on the smart map. © 2018 Milestone Systems A/S
