Hardware acceleration (explained)
Hardware acceleration improves the decoding capability and performance of the computer running XProtect Smart Client. This is particularly useful when you view multiple video streams with high frame rate and high resolution.
Note: XProtect Smart Client supports hardware accelerated decoding using Intel® and NVIDIA® GPUs. Milestone does not recommend the use of Scalable Link Interface (SLI) configuration of your NVIDIA display adapters.
Follow the steps described in the next sections to examine your PC to make sure that all hardware acceleration resources are available.
© 2018 Milestone Systems A/S
