In setup mode, in the Properties pane, you can specify the settings for Matrix positions.
Name |
Description |
Window index |
Change the Matrix position's ranking by choosing a different number. You can only choose a number in the range that corresponds to the number of Matrix positions in your view. 1 is the primary position in which video from the newest event is always shown, 2 displays video from the previously detected event, 3 displays video from the event detected before the event in position 2, and so on. |
Connection Settings... |
Lets you specify the TCP port and Password for transferring Matrix-triggered video from the surveillance server to the XProtect Smart Client view. This is only available when Matrix position 1 is selected; other Matrix positions inherit the connection settings specified for position 1. By default, the TCP port used for Matrix is 12345. Consult your surveillance system administrator about which port number or password to use. |
© 2018 Milestone Systems A/S
