This website uses cookies to give you the best possible experience. By using this site, you accept our use of cookies. Read our Cookie Policy to learn more.
Ok
Milestone Systems
Milestone Mobile 2019 R1
Observe and communicate
Log in to the Milestone Mobile app
If your system administrator has set up two-step verification for your user account, you are asked for an additional login step when you log in to the Milestone Mobile app and connect to the server.
The first step is your user name and password. The second step is to enter the verification code that you receive via email.
To log in with two-step verification:
1. Tap the Milestone Mobile app icon.
2. From the list of servers, tap the relevant server.
     Note: If you have specified a default server, you won't see the list of servers.
3. You are asked for a verification code and the system sends it to your email address. If in doubt, ask your system administrator for the email address.
4. Open your email program and make a note of the numbers.
5. Enter the code in the Milestone Mobile app and tap Save icon for Android  to save.
     You are ready to view video.
If you do not use the verification code within a specified expiry period (the default period is five minutes), the verification code times out. Request a new code on the page where you enter the code.
If you exceed the number of allowed code entry attempts (the default number is three), you will be blocked. In that case, you must log out of the Milestone Mobile app and log in again.
Viewing live video
You can view video only on cameras that are set up in views in XProtect Smart Client. You cannot create views in Milestone Mobile. Also, the Milestone Mobile client displays only video. If a view in XProtect Smart Client contains other types of content, such as maps, text, or HTML pages, the content does not display.
When you connect to a server, the Milestone Mobile client lists your views.
  • Androide -  Access your views on the Views page
  • iOS - Access your views on the Milestone Mobile page
The list of views offers the following information:
  • The type of view. This can be All CamerasShared views that everyone can access, or Private views that you have set up in XProtect Smart Client and only you can access
  • The name of the view. For example, Building A
  • The number of cameras available in the view
Start viewing live video from a camera
1. Tap a view to display the cameras it contains.
2.  Tap the preview image for the camera.
3. Optional. Tap audio disabled to start or audio enabled to stop playing audio (Only for cameras that have microphones attached).
4. Optional. Tap and hold PTT available icon to start push-to-talk. Release the icon PTT-in-active-state-icon to end transmitting audio (Only for cameras that have speakers).
Stop viewing live video from a camera, or view another camera
To stop viewing live video:
  • Android - Tap the Back button on your device
  • iOS - Tap Close in the upper left corner
To view video from another camera in the view:
  • Swipe right or left
Search for a specific camera
If you have lots of views and cameras, you can find a camera by searching for the camera name.
1. Above the list of views, tap the Search icon.
2. Enter the name of the camera.
Filter your views
If you want to see a particular type of view only, or if you want to see fewer views, you can apply a filter. All views are displayed when you tap Filter, regardless of whether they are shown or filtered. You can always choose to include a view again.
How you filter views depends on the operating system on your device.
1. To filter views:
  • Android - Tap Filter icon for Android. If a filter us already applied, the icon is blue
  • iOS - Tap Filter in the upper right corner
2. To include or exclude a view, tap the view or use the slider.
3. To apply the filter and return to the list of views:
  • Android - Tap Save icon for Android in the upper right corner
  • iOS - Tap Done in the upper right corner of the navigation pane
Discard filter selections
If you haven't saved your selections yet, you can discard them:
  • Android - Tap Close icon for Android in the upper left corner
  • iOS - Manually undo your selections, or tap Servers to go to the list of servers
Interact with live video
Use pan-tilt-zoom controls and PTZ presets
If you're viewing video from a pan-tilt-zoom (PTZ) camera, tap PTZ or PTZ controls icon for Android to use the PTZ controls. Tap controls once to pan or zoom one step.
If your administrator created PTZ presets for the PTZ camera in the Management Client or Management Application, you can use PTZ presets on your device in PTZ mode. PTZ presets are predefined positions in the view.
How you access PTZ presets depends on the operating system on your device.
  • Android - Tap Presets icon for Android
  • iOS - Tap PTZ
On the Presets context menu or page, select a preset to start using it.
Zoom in or out
You can zoom in or out to get a better look at the video.
  • To zoom in, pinch out or tap +
  • To zoom out, pinch in or tap -
Milestone Mobile uses digital zoom.
Crop or fit images to the screen
You can resize images to fit your screen, or you can crop them. By default, images are fitted to the screen.
The outer parts of images are removed. Tap twice to crop images to fill screen and preserve the image's aspect ratio.
Display other cameras in the view
If your view contains other cameras, you can swipe right or left to display their video.
Switch to playback mode
If you're recording, and something happens that you want to review, you can switch to playback mode to review the footage or start an investigation.
Tip: To keep an eye on the live video while you investigate, turn on picture-in-picture by tapping Hide/show Live PiP.
  • To switch to playback mode, tap Playback icon Playback.
Using actions in Milestone Mobile
If your system administrator has given you permission, you can trigger actions if you need to. In the clients, actions are outputs and events that you can activate. For example, you can:
  • Start or stop recording
  • Switch to a different frame rate
  • Trigger SMS and email notifications
  • Move PTZ cameras to PTZ preset positions
  • Activate hardware output
View and trigger actions
You can view and trigger actions from the following locations
  • The list of views
  • When viewing live video
  • The Actions page
1. To display a list of actions, do one of the following
  • Android and iOS - Tap Actions icon iOS
2. To trigger an action, do one of the following:
  • Android and iOS - In the list of actions, tap the action, and then confirm that you want to trigger it.
Use picture-in-picture
If you see something that you want to investigate, but don't want to stop observing the current situation, you can display the live video in picture-in-picture (PiP) and simultaneously play back the video.
PiP example
To turn on PiP:
1. While viewing live video from the camera, tap Playback icon Playback.
2. Depending on the operating system on your device, do one of the following:
  • Android - Tap Menu icon for Android, and then tap Hide/Show Live PiP
  • iOS - Tap Menu, and then tap Hide/Show Live PiP
Return to live video
 To view the live video in full screen, tap the PiP window.
Take a snapshot
When you view live video or play it back, and you find something interesting, you can take a shapshot of it.
Snapshots are saved on your mobile device.
  • Android - View snapshots on your device's SD card at /mnt/sdcard/Milestone
  • iOS - View snapshots in the Photo Library
Note: You cannot change the locations.
To take a snapshot in live mode or playback mode:
  • Android - In live mode, tap Snapshot icon for Android. In playback mode, tap Context menu icon for Android, and then tap Snapshot
  • iOS - In Live mode, tap Snapshot icon Snapshot
Listening to audio (explained)
Milestone Mobile client supports incoming audio when you:
  •           View live video (see Viewing live video)
                Note: You can play the incoming live audio from microphones attached to cameras even when there is no live video streaming from these cameras.
  •          Playback video recordings (see Find and view video recordings)
The incoming audio is also available in:
  •          Investigations (see View or create an investigation)
  •          Alarms (see View alarms)
  •          Access control (see View doors and take action, Respond to access requests, Investigate access control events)
Push-to-talk (explained)
Milestone Mobile client supports the push-to-talk (PTT) feature:
  • While you are watching live video from one camera (see Viewing live video)
  • In Access Control (see View doors and take action and Respond to access requests)
The feature allows you to communicate through the VMS system from the microphone of your mobile device with people near a video camera with audio equipment.
Note: You must allow Milestone Mobile client app to have access to the microphone of your mobile device (see Requirements for using push-to-talk).
When the push-to-talk (PTT) feature is available for use, you will see the Push-to-talk button on the camera toolbar. Its icon has the following states:
   Icon    Description
  PTT available icon (Available)   Shows that the push-to-talk (PTT) feature is available and that you fulfilled the necessary requirements for using it. Tap and hold to start using push-to-talk. Release the button to end transmitting audio.
  PTT-in-active-state-icon  (Active)
Shows that you are currently using the push-to-talk (PTT) feature. The microphone of your mobile device and the speaker of the video camera are in an active state. The blue pulsating circle indicates the sound level.
  PTT disabled icon  (Disabled)
Shows that the push-to-talk (PTT) feature is available, but that you did not fulfill the necessary requirements for using it (see Requirements for using push-to-talk).
Rules for interrupting push-to-talk
Based on the level of your user rights (Administrators or Operators), there are two rules for interrupting a push-to-talk session in live mode:
  • Users with the same level of user rights cannot interrupt each other
  • Users with a lower level of user rights (Operators) cannot interrupt users with a higher level of user rights (Administrators)
MILESTONE SYSTEMS GLOBAL WEBSITE
A LEADER IN IP VIDEO MANAGEMENT SOFTWARE AND SURVEILLANCE SOLUTIONS
Call us at +45 88 300 300  Contact Us  Terms of Use  Privacy Policy  Cookie Policy  MAP Policy
Copyright © 2019 Milestone Systems A/S. All rights reserved.
