2026 R2
XProtect Smart Client 2026 R2 Product System Requirements
Computer running XProtect Smart Client, Protect Smart Client - Player and XProtect Smart Wall
Name Description
Operating system Microsoft® Windows® 11 Pro
  Microsoft® Windows® 11 Enterprise
Software Microsoft® .NET 4.8.1 Framework
  DirectX 9 & DirectX 11
Hardware acceleration Intel® GPUs are supported from Intel® CPU 6th generation and newer with a video driver of at least 21.0.xxx (AV1 codec is currently not supported)
  Using Intel® GPU on Intel® CPU 12th generation and newer, requires at least driver version 31.0.101.3413.
  NVIDIA GPUs are supported from version 6.x (Pascal) and newer with a driver version of at least 555.85. (To support AV1, version 8.6 (Ampere) is required)
Note: In order to install patches from XProtect 2024 R1 and onwards , you must have Microsoft® .NET 8 Runtime installed on the machine before you can run the XProtect Patch installer.
