| XProtect LPR | |
| Name | Description |
| Operating System | Microsoft® Windows® 10 Pro (64 bit) |
| Microsoft® Windows® 10 Enterprise (64 bit) | |
| Microsoft® Windows® 10 IoT Enterprise LTSB (Long-Term Servicing Branch)2016 (version 1607 or later) | |
| Microsoft® Windows® 10 IoT Enterprise, version 1803 or later (64 bit), IoT Core | |
| Microsoft® Windows® 11 Pro (64 bit) | |
| Microsoft® Windows® 11 Enterprise (64 bit) | |
| Microsoft® Windows® Server 2016 (64 bit): Essentials, Standard and Datacente | |
| Microsoft® Windows® Server 2019 (64 bit): Essentials, Standard and Datacenter | |
| Microsoft® Windows® Server 2022 (64 bit): Essentials, Standard and Datacenter | |
| Software | Microsoft® .NET 4.7.2 Framework |
| Microsoft® .NET 10 Runtime | |
| Hardware | XProtect LPR server requires an Intel 4th generation CPU or later |
Note: In order to install patches from XProtect 2024 R1 and onwards , you must have Microsoft® .NET 8 Runtime installed on the machine before you can run the XProtect Patch installer.
