Name |
Description |
| Operating System | Microsoft® Windows® 10 Pro (64 bit) |
| Microsoft® Windows® 10 Enterprise (64 bit) | |
| Microsoft® Windows® 10 IoT Enterprise LTSB (Long-Term Servicing Branch)2016 | |
| Microsoft® Windows® 10 IoT Enterprise (64 bit) | |
| Microsoft® Windows® 11 Pro | |
| Microsoft® Windows® 11 Enterprise | |
| Microsoft® Windows® 11 IoT Enterprise LTSC 2024 | |
| Microsoft® Windows® Server 2019: Essentials, Standard and Datacenter | |
| Microsoft® Windows® Server 2022: Essentials, Standard and Datacenter | |
| Microsoft® Windows® Server 2025: Essentials, Standard and Datacenter | |
| To run clustering/failover management servers, you need a Microsoft® Windows® Server 2019/2022/2025 Standard or Datacenter edition | |
| File system | For the Recording Storage Location, NTFS file system is recommended |
| SQL Versions | Microsoft SQL Server® 2017 |
| Microsoft SQL Server® 2019 | |
| Microsoft SQL Server® 2022 | |
| Microsoft SQL Server® 2025 | |
| Software | Microsoft® .NET 10 Runtime |
| Microsoft® .NET 4.7.2 Framework | |
| DirectX 11 | |
| Hardware acceleration | Intel® GPUs are supported from Intel® CPU 6th generation and newer with a video driver of at least 21.0.xxx (AV1 codec is currently not supported) |
| Using Intel® GPU on Intel® CPU 12th generation and newer, requires at least driver version 31.0.101.3413. | |
| NVIDIA GPUs are supported from version 6.x (Pascal) and newer with a driver version of at least 555.85. (To support AV1, version 8.6 (Ampere) is required) | |
Not sure which hardware to buy or how many devices you can run on your current hardware?
Then we recommend our XProtect Server Calculator. For more information or inspiration check out our Husky Documentation.
Note: In order to install patches from XProtect 2024 R1 and onwards , you must have Microsoft® .NET 8 Runtime installed on the machine before you can run the XProtect Patch installer.
