XProtect Expert
2026 R2
XProtect Expert 2026 R2 Product System Requirements
  Computers running XProtect Expert software
Name
Description
Operating System Microsoft® Windows® 10 Pro (64 bit)
  Microsoft® Windows® 10 Enterprise (64 bit)
  Microsoft® Windows® 10 IoT Enterprise LTSB (Long-Term Servicing Branch)2016
  Microsoft® Windows® 10 IoT Enterprise (64 bit)
  Microsoft® Windows® 11 Pro
  Microsoft® Windows® 11 Enterprise
  Microsoft® Windows® 11 IoT Enterprise LTSC 2024
  Microsoft® Windows® Server 2019: Essentials, Standard and Datacenter
  Microsoft® Windows® Server 2022: Essentials, Standard and Datacenter
  Microsoft® Windows® Server 2025: Essentials, Standard and Datacenter
  To run clustering/failover management servers, you need a Microsoft® Windows® Server 2019/2022/2025 Standard or Datacenter edition
File system For the Recording Storage Location, NTFS file system is recommended
SQL Versions Microsoft SQL Server® 2017
  Microsoft SQL Server® 2019
  Microsoft SQL Server® 2022
  Microsoft SQL Server® 2025
Software Microsoft® .NET 10 Runtime
  Microsoft® .NET 4.7.2 Framework
  DirectX 11
Hardware acceleration Intel® GPUs are supported from Intel® CPU 6th generation and newer with a video driver of at least 21.0.xxx (AV1 codec is currently not supported)
  Using Intel® GPU on Intel® CPU 12th generation and newer, requires at least driver version 31.0.101.3413.
  NVIDIA GPUs are supported from version 6.x (Pascal) and newer with a driver version of at least 555.85. (To support AV1, version 8.6 (Ampere) is required)
Not sure which hardware to buy or how many devices you can run on your current hardware?
Then we recommend our XProtect Server Calculator. For more information or inspiration check out our Husky Documentation.
Note: In order to install patches from XProtect 2024 R1 and onwards , you must have Microsoft® .NET 8 Runtime installed on the machine before you can run the XProtect Patch installer.
